Added View > Actual Size (Command-0) menu item.
Changed View > Zoom In menu shortcut to Command-+
Changed Item > Delete Items to delete child items IF selected item is folded.
Fixed drawing of task items leading dash to fit space.
Updated the default styles to scale the indentation width as the font size changes. To use this new default you will need to:
Show your existing
user.less
file in the Finder using TaskPaper > File > Open Application Folder. -
Quit TaskPaper.
Delete the
user.less
file. -
Restart TaskPaper.
Just an FYI that I’m still seeing the dashes without text padding. Not sure if that was part of that fix.
It was… I think I know the problem. Can you look in your theme for an “expansion” attribute applied to button links I think… delete that and I think ti will fix the problem.
I also just realized that I broke the ability to style those dashes… will get that fix into a release later today.
Yep. Totally fixed it.
Hi, I am not able to see the checkbox now in my tasks !!! I prefer to see a Checkbox than a dash. Please let the checkbox back!!.. Or just make this optional in preference. What do you think ?
KInd regards
Fer
I agree - I’d like to see checkboxes as a preference.
