A suggestion for improving the @done task archive function (CMD - SHIFT - D)
When archiving projects via CMD - SHIFT - D an option is build in to add the project name as tag
So “A very long project name with project number FA1234” becomes @project(A very long project name with project number FA1234).
I suppose many of us use a unique number for a project, which can be defined with a regex (I do ;)). So it would be nice when you could define in the TP preferences a regex for the unique project number. When archiving only the regex value is added to the @project tag:
“A very long project name with project number FA1234” becomes @project(FA1234). When no match is available, the complete project name is used.
I think this can make the archive much more uncluttered.
regards,
feek
