Styling issue with '_' emphasis
I am seeing the following issue with styling text using _ for emphasis. Source code:
archivename-_yyyy_-_mm_-_dd_\_b_bbb_.zip
This renders in FT 2.0.2 as
whereas I would expect it to render as
The ‘’ is escaping the ‘_’ before the ‘b’ (taking away its special meaning), leaving the following two '_'s around the three 'b’s to mean that they should be interpreted as italics emphasis.
Is this a problem with the display engine in FT, or am I doing something wrong?
Thanks, Christian
I notice that MultiMarkdown Composer does the same (even if you replace the escaped underscore with a literal _ HTML entity)
(Top two examples above in MMC)
There seem to be permutations which get closer to what you are aiming for …
(Third example above in MMC)
Rob
