I use TaskPaper 2 and I am thinking about upgrading to version 3. My only problem is that my smartphone is an Android-based one and I am looking for a way to have TaskPaper integration with SimpleTask (or another android app). Is there a simple way to do this?
Best regards
There’s always a way… but sometimes “the way” might involve more work then what you started with
I’m not very familiar with Androids offerings. Can anyone else suggest the best way to use TaskPaper on android? I know a few people have talked about developing TaskPaper format based apps for Android, but I’m not sure if any have been released yet?
