Showing all tasks before running a search
I’m hoping someone can help me out with an Alfred workflow. I am able to run a workflow that shows all of my tasks due within X days, and it works great, but it only shows the tasks within the last-selected project. I’m trying to figure out how to clear the selected project before running the search so that I see all tasks due in X days across all of the projects.
Thank you for any suggestions. I’m still struggling with the transition from Applescript to Javascript.
Can you show us the .js which you are using at the moment ?
( We may just be able to fix that quickly for you )
No problem – and thanks for responding – it is actually one from this forum that you had posted:
var alfredText = "- " + "{query}";
// SEND TEXT LINES TO INBOX: PROJECT OF FRONT TASKPAPER DOCUMENT
// Predraft version 0.02
// This version just gets its text from the clipboard
// Could be adapted for Keyboard Maestro, LaunchBar, Alfred etc
// N.B. you need to give a filepath to an existing TaskPaper document
// in the:
// OPTIONS SETTINGS AT BOTTOM OF SCRIPT
(function (dctOptions) {
    'use strict';
    // TASKPAPER CONTEXT ***************************************
        // FIND OR MAKE A PROJECT TO HOLD INCOMING TEXT
        // String -> String -> {project: tpItem, new: Bool}
        function projectAtPath(strProjectPath, strDefaultName) {
            var strDefault = strDefaultName || 'Inbox:',
                outline = editor.outline,
                lstMatch = outline.evaluateItemPath(strProjectPath),
                blnFound = lstMatch.length > 0;
            return {
                project: blnFound ? lstMatch[0] : (function () {
                    var defaultProject = outline.createItem(
                        strDefault)
                        outline.root.appendChildren(
                            defaultProject
                    return defaultProject;
                new: !blnFound
        // parsedLines :: String -> [{indent: Int, text:String, bulleted:Bool}]
        function parsedLines(strText) {
            var rgxLine = /^(\s*)([\-\*\+]*)(\s*)/;
            return strText.split(/[\n\r]+/)
                .map(function (x) {
                    var ms = rgxLine.exec(x);
                    return {
                        indent: (ms ? ms[1] : '')
                            .replace(/    /g, '\t')
                            .length,
                        text: x.slice((ms ? ms[0] : '')
                            .length),
                        bulleted: ms[2].length > 0
        // textNest :: [{indent:Int, text:String}, bulleted:Bool]
        //          -> Tree {text:String, nest:[Tree]}
        function textNest(xs) {
            var h = xs.length > 0 ? xs[0] : undefined,
                lstLevels = [{
                    text: undefined,
                    nest: []
            if (h) {
                var lngBase = h.indent;
                xs.forEach(function (x) {
                    var lngMax = lstLevels.length - 1,
                        lngLevel = x.indent - lngBase,
                        dctParent = lngLevel > lngMax ? lstLevels[
                            lngMax] : lstLevels[lngLevel],
                        dctNew = {
                            bullet: lngLevel === 0 || x.bulleted,
                            text: x.text,
                            nest: []
                    dctParent.nest.push(dctNew);
                    if (lngLevel > lngMax) lstLevels.push(dctNew);
                    else lstLevels[lngLevel + 1] = dctNew;
            return lstLevels[0];
        // insertNest :: tp3Node ->
        //      Tree {text:String, nest:[Tree], bullet:Bool} -> ()
        function insertNest(oParent, oTextNest) {
            // placeSubNest :: tp3Node -> Tree {text:String, nest:[Tree], bullet:Bool} -> ()
            function placeSubNest(oParent, lstNest) {
                // IMMEDATE CHILD NODES CREATED,
                if (lstNest.length > 0) {
                    var lstChiln = lstNest.map(function (dct) {
                        return outline.createItem((dct.bullet ?
                            (dct.text || ''));
                    // AND PLACED UNDER EXISTING PARENT LINE
                        oParent.appendChildren(lstChiln);
                    // THEN RECURSION WITH EACH CHILD FOR
                    // ITS DESCENDANTS, IF ANY
                    zipWith(function (dctNest, oNode) {
                        var lstSub = dctNest.nest;
                        if (lstSub.length > 0) {
                            placeSubNest(oNode, lstSub);
                    }, lstNest, lstChiln);
            // Ensure that the nest has a virtual root
            var outline = editor.outline;
            // Place the nest beneath the parent
            placeSubNest(oParent, oTextNest.nest)
        function zipWith(f, xs, ys) {
            var ny = ys.length;
            return (xs.length <= ny ? xs : xs.slice(0, ny))
                .map(function (x, i) {
                    return f(x, ys[i]);
        // TASKPAPER CONTEXT MAIN:
        // 1. FIND OR CREATE AN INBOX
        var outline = editor.outline,
            mInbox = projectAtPath(options.inboxPath, 'Inbox:'),
            itemInbox = mInbox.project;
        // 2. PARSE THE INCOMING TEXT TO A NEST
        var dctNest = textNest(
            parsedLines(
                options.textLines
        // 3. INSERT THE TEXT NEST IN THE INBOX
        insertNest(
            itemInbox,
            dctNest
    // JAVASCRIPT FOR AUTOMATION  CONTEXT ***********************
    // fileExists :: String -> Bool
    function fileExists(strPath) {
        var error = $();
        $.NSFileManager.defaultManager
            .attributesOfItemAtPathError(
                ObjC.unwrap($(strPath)
                    .stringByExpandingTildeInPath),
                error
        return error.code === undefined;
    //  JSA MAIN ***********************************************
    //1. DOES THE FILE EXIST ?
    var strFullPath = ObjC.unwrap(
        $(dctOptions.filePath)
    if (fileExists(strFullPath)) {
        var tp3 = Application("TaskPaper"),
            d = tp3.open(Path(strFullPath));
        //2. And an inbox in this file
        //3. and place the text
        if (d) {
            return d.evaluate({
                withOptions: dctOptions
    } else {
        sa.activate();
        sa.displayDialog('File not found:\n\n' + strFullPath, {
            //defaultAnswer: undefined,
            //buttons : undefined,
            defaultButton: 'OK',
            //cancelButton : undefined,
            withTitle: "Quick entry",
            withIcon: sa.pathToResource('TaskPaperAppIcon.icns', {
            }), // 'note'
            givingUpAfter: 30
    // SCRIPT OPTIONS
    inboxPath: '//Inbox and @type=project[-1]',
    filePath: '/Users/mattm/Library/Mobile Documents/com~apple~CloudDocs/Tasks/Tasks.taskpaper',
    textLines: alfredText
It sounds like the itemPath you need may be something like:
'//@due <[d] now+' + options.days + 'd'
Depending on what you mean by ‘see’ all tasks (concatenated string ? array of strings ? array of records for further processing ?) you could harvest a list of things due within N days like this:
function run() {
        return editor
            .outline
            .evaluateItemPath('//@due <[d] now+' + options.days + 'd')
            .map(function (item) {
                return item.bodyString;
    var ds = Application('com.hogbaysoftware.TaskPaper3')
        .documents;
    if (ds.length) {
        return ds[0].evaluate({
            withOptions: {
                days: 6
In that form it would give you the list as an array
["- alpha @due(2016-05-07)", "- beta @due(now + 2d)", "- gamma @due(now + 3d)",
"- delta @due(now + 4d)", "- epsilon @due(now + 5d)", "- zeta @due(2016-05-12)"]
and adding .join('\n')
would rewrite that as a text of \n delimited lines
            }).join('\n')
Notice that the value N, where N is a number of days, is coming in through the withOptions record/object
And to clear a filter, you might write something like:
function run() {
        editor.itemPathFilter = '';
        .documents;
    if (ds.length) {
            withOptions: {}
Thank you! I will give this a try over the weekend.
