Scrolling and selection in Birch 0.1.0 'Dev'
I notice that scrolling the window seems to trigger block selection.
Not sure if that is by design, or whether I am failing to switch out of a mode
This is a bug I think… if you mean the part where you drag scroll bar and things get selected? That’s not intentional. I normally always use keyboard or mouse wheel for scrolling, so that’s the workaround at the moment.
This should be fixed in latest release.
