Scripts for converting FoldingText 2 ⇄ TaskPaper 3 (copy/paste)
Two scripts for:
  1. Copying from FoldingText 2 in TaskPaper 3 format, and
  2. copying from Taskpaper 3 in in FoldingText 2 format.
FoldingText Extensions Wiki
I get an error with the TP to FT script:
In the line
tell item 1 of lstDocs to set varResult to (evaluate script "pstrJS")
I get the error
Expected “,” but found “script”.
I wonder if you accidentally skipped a line in a copy / paste ?
(Or perhaps didn’t see the This file has been truncated line at the bottom of the partial GitHub window on the Forum’s Discourse page ?)
I just copy-pasted and ran the script from the full page without a problem, but HTML displays of Applescript can introduce problems, so the best approach is always to get the script straight from the Github repository zip:
https://github.com/RobTrew/txtquery-tools/archive/master.zip
(or from the ‘raw’ page:
https://raw.githubusercontent.com/RobTrew/txtquery-tools/master/utilities/CopyTPasFT.applescript
(PS this script is, of course, for TaskPaper 3 (dev) builds, which use a different script engine from TP2)
Whoops, that’s what it was: I’m using TP 2. Thanks for pointing that out!
