Script to batch-delete particular types of @tag
Tags which I use while developing and reorganising a document sometimes need to be stripped out of production copies.
Here is a script which:
  1. Shows a sorted menu of the different kinds of tags in the current document,
  2. allows choice of one or more tag-types (⌘-click to multi-select)
  3. deletes all tags of the chosen type(s).
(In case of unintentional deletion, use ⌘Z undo)
property pTitle : "Batch delete tags from current document"
property pVer : "0.2"
property pAuthor : "RobTrew"
property pDescription : "
property pjsListTags : "
	function(editor) {
		return editor.tree().tags(true).sort();
property pjsStripTags : "
	function(editor, options) {
		var tree=editor.tree(), lstTags = options.strip;
		tree.nodes().forEach(function (oNode) {
			Object.keys(oNode.tags()).forEach(function(strTag) {
				if (lstTags.indexOf(strTag) !== -1) {
					oNode.removeTag(strTag);
on run
		set lstDocs to documents
		if lstDocs ≠ {} then
			tell item 1 of lstDocs
				set lstTagsFound to (evaluate script pjsListTags)
				if lstTagsFound ≠ {} then
					-- CHOOSE WHICH TAG-TYPES TO DELETE
					set varChoice to choose from list lstTagsFound with title pTitle & tab & pVer with prompt ¬
						"Choose tag types to delete" default items {item 1 of lstTagsFound} ¬
						OK button name "OK" cancel button name "Cancel" with empty selection allowed and multiple selections allowed
					if varChoice = false then return missing value
					set lstTagsChosen to varChoice
					-- AND DELETE ALL INSTANCES OF THE CHOSEN TAG TYPES
					set varResult to (evaluate script pjsStripTags with options {strip:lstTagsChosen})
				end if
			end tell
		end if
	end tell
end run
FoldingText Extensions Wiki
