Script: Open OPML outlines in FoldingText 2
A script to Open OPML outlines in FoldingText
Installation
This is an applescript which uses a Python helper script to convert from OPML to FoldingText Markdown.
It therefore needs:
  1. To be saved as a Compiled Script Bundle .scptd
    (not as .applescript or flat .scpt)
  2. To have the Python script OPML2FT.py copied into the script bundle’s Contents/Resources folder. For example as: FT2ImportOPML.scptd/Contents/Resources/OPML2FT.py
To open an .scptd bundle, ctrl-click it, and choose ‘Show Package Contents’
(Note that if you accidentally do a Save As in a format other than .scptd, the bundle format and the Python script will be lost.
You will then need to save again as .scptd, and manually place a copy of OPML2FT.py in FT2ImportOPML.scptd/Contents/Resources/)
Use
