if I use Rows/Delete Rows on Level 1 under a Level 0 that has child items, then everything under Level 1 disappears into Level 0 without a warning.
In Taskpaper, the orphaned Level 1 children turn into children of Level 0, but they don’t disappear from sight. I have to expand and contract Level 0 first before the Level 1 children disappear.
I suggest that Bike’s edit mode behaviour should mimic TP’s, and all outline mode behaviour should be different.
TaskPaper handled better/differently by keeping those children visible while also allowing for Alpha’s original children to remain collapsed. TaskPaper’s solutions was better in some respects, but more complex to implement and also made the view a bit harder to understand.
@Doug I do agree that Bike’s current behavior is problematic, though I’m not sure if I’ll restore TaskPaper’s behavior because it’s more complex to implement and makes the view a bit harder to understand.
In this case maybe the most strait forward thing I can do is just expand “Level 0” in this case?
as an alternative to the middle figure, expanding Level 1 would be okay, but not quite as good because you could imagine level 1 being really big. is there a way to highlight the newly added children? or is it possible to scroll down?
