Hello Developers,
I would like to ask how to batch convert multiple .bike format files to .opml format files?
I tried to change the file suffix directly from .bike to .opml, but after the change the file prompts that it is corrupted (as shown in the picture).
The only conversion method I know so far is to open the .bike file → File → Duplicate → select the format to be saved.
So, is there any bulk modification method?
Thank you for your reply,
Jason
