Plugin Function Error
I just started to learn how to write a plugin and run already into a problem. My main.js looks like this:
	'use strict';
    var Extensions = require('ft/core/extensions').Extensions;
    Extensions.addInit(function (editor) {
        editor.addKeyMap({
            'Cmd-T' : function (editor) {
                editor.setTextContent(editor.textContent.toLowerCase());
If I test this in the SDK I get an error:
[Error] TypeError: undefined is not a function (evaluating 'editor.textContent.toLowerCase()')
(anonymous function) (codemirror.js, line 2128)
Obviously I’m doing something fundamentally wrong, but what?
Try changing editor.textContent.toLowerCase() to editor.textContent().toLowerCase()textContent is a function not a property. Should maybe have named it getTextContent to make it more standard javascripty, but javascript conventions don’t seem 100% in that direction, so instead I followed objective-c convention in this case.
Thank you, this did the trick.
I had looked at the documentation, but obviously I’m suffering from selective bracket blindness. Thanks again.
