Plugin for "write or it will be erased" mode
Hi Jesse
I’ve been looking all over the place for an app that can “force” you to write for a definite amount of time or number of words in order to overcome writing blocks. I used to do this in “flowstate” a clunky app that eventually got pulled off from the app store.
The behaviour I am looking is quite straightforward: define a time slice or a number of words goal and just write, if you stop writing for more than — let’s say — 5 seconds, everything written since then is erased.
I have no programming skills whatsoever, but I was wondering perhaps this feature could be built as a “mode”. Since there are (to my knowledge) no writing apps offering this feature I think it might be a nice addition. However, there is always the possibility that I might be the only person with this particular “itch” :slight_smile:
Anyways, thanks a lot for a great tool, I’ve been a huge fan since the 1.0 release.
Rodrigo
Wow, that sounds pretty extreme and dangerous!
With that said a plugin to do this is pretty simple. I’ve added a “speed up” plugin to the plugin repo:
Install it. Then to make it work:
Edit > Run Command > Begin Speed Up
When you are ready to finish:
Edit > Run Command > End Speed Up
And while you are typing… if you are too slow text will be erased. But you can “Undo” to get it back! :smile:
Jesse
Awesome!
Thank you very much Jesse, works like a charm. Loved the undo safe net :).
And really, thank you for taking the time to do this.
