Oddly, I am unable to paste into the window that opens when I launch Taskpaper 3. If I start a new document, I can paste into it.
What is that document that opens when you launch TaskPaper? Is it a document that you’ve created, or just the default document? For me (testing on 10.10 right now) pasting into a document opened by TaskPaper at startup seems to work ok.
The default document. It is still happening. Only the first line is pasted unless I open a new Taskpaper document in which case my entire paste board appears.
I’m not really sure where to go on this one. I can’t reproduce the problem myself. Here are some thoughts:
- If anyone else can reproduce this please post here to let me know!
- Can you type in the new document? If so what happens if you type into the new document for a while and then try to paste?
- Does the problem happen if you run TaskPaper from your Guest User Account?
- Do you see any errors in Console.app when you try to paste?
Maybe this helps - the problem does not happen if I show welcome text. If I press ctrl+v in the welcome text doc, everything pastes. Back to the default doc, only the first line pastes.
