Org mode style tables
Just wanna say that I love using FoldingText!
A great addition would be if FoldingText supported easy creation of text tables, similar to Emacs’ Org mode tables.
Otherwise, keep up the good stuff!
No immediate plans, but this is on my list.
In the meanwhile, you can:
  • Type a few lines of data,
  • use the | character to separate fields,
  • and automatically convert to a pretty-printed MMD table
by using a KeyBoard Maestro script:
Thanks for the tip, script works great! Will look forwards to having it natively eventually :slight_smile:
