Navigate document (TOC pop up)
Maybe I just do not find the obvious, so bear with me.
In longer documents, a TOC in a sidebar or a collapsable pop up (like in Marked) might be helpful. I thought there is something of this kind in FoldingText, but cannot find it anywhere…
Is there something like that to navigate easily, or do you plan to implement it?
Does Folding Text use Projects List sidebar like Taskpaper does?
Have you seen View -> Focus Heading? It’s command-option-U. That’ll focus the document on the heading you select though, so it’s not quite like the TOC in Marked.
That was what I was looking for but did not find again, thanks a lot!
What about creating a sidebar with the TOC for even better navigation?
Sidebar navigation is an eventual goal.
Wonderful!
Anyway, thanks for the beautiful editor.
