Key combinations not recognized
Hi, I tried FT and like it. But there is a bug that does not occur in TaskPaper 2 but in the new beta version as well as in Folding Text:
I have these characters mapped to a certain key combination:
āīūēōŏŭ
    ĀĪŪĒŌŎŬ
The combination is ctrl-a … ctrl-ö, ctrl-ü; and for capitals respective.
But some combinations are not recognized:
īūŏŭ
ĪŪŌŎŬ
I thought that there are shortcuts in the menus, but they are not. How can I get these keys back working?
Best,
Maria
FoldingText implements its own internal keybinding system that overrides the system menus when there is a conflict. For example Ctrl-A is mapped to ‘moveToBeginningOfParagraph’ inside FoldingText and that will take precedent over anything put into the OS X menu system. To override an internally defined keybinding you’ll need to use a plugin.
I’ve just create an example plugin that you can start with.
Great, thanks a lot, this helps.
But – I do not know JavaScript, just changed from ā to ō, but cannot add other keybindings.
Where do I have to add the other patterns, and which brackets do I have to use?
Sorry, if you add one more example, I know how to go on.
Best,
Maria
Sure… repeat the pattern and separate each one with a comma.
Like this:
editor.addKeyMap({
	'Ctrl-A' : function (editor) {
		editor.replaceSelection('â');
	'Ctrl-U' : function (editor) {
		editor.replaceSelection('û');
The modifier options are:
Shift-, Cmd-, Ctrl-, and Alt- (in that order)
Works great! Thanks for your help,
M
