Hello all!
Is there any documentation on Outline.getOutlines?
My searches have turned up nothing.
Any example scripts showing Outline.getOutlines in action?
Jim
Hello all!
Jim
I don’t know if this sheds light on reading the contents of another open outline (from the evaluation space of the front outline document):
(As in the Finding Outlines
section of: Outline · GitBook)
(A possibly unfamiliar element is that we access the getOutlines()
method from the Outline
class (hence initial CAP) rather than from the outline
instance of the editor
object.)
"use strict";
// Assuming that more than one TaskPaper 3 document
// is open ...
const TaskPaperContext = editor => {
// outline = editor.outline,
// idOfActiveDocOutline = outline.id,
// Method of Outline class rather than an
// outline instance, hence the upper case.
allOutlines = Outline.getOutlines(),
allIDs = allOutlines.map(o => o.id),
secondOutline = Outline.getOutlineForID(
allIDs[1]
// Rough peek at contents of another open outline ...
return secondOutline.toString();
// ------------------- JXA CONTEXT -------------------
const main = () => {
// We evaluate the script in the front document,
// while also referencing other documents (outlines)
taskpaper = Application("TaskPaper"),
documents = taskpaper.documents,
intDocs = documents.length;
return 1 > intDocs ? (
"No documents open in TaskPaper"
) : 2 > intDocs ? (
"Demo needs more than one document open in TaskPaper"
const frontDoc = documents.at(0);
return frontDoc.evaluate({
script: `${TaskPaperContext}`
or, to recover the full text (bar tags) of another outline, if two or more are open, perhaps something like:
"use strict";
const TaskPaperContext = () => {
// eslint-disable-next-line no-undef
const allOutlines = Outline.getOutlines();
return 1 < allOutlines.length ? (
allOutlines[1].root.children
.flatMap(tpLinesForNode)
.join("\n")
) : "Only one outline open in TP.";
// ------- GENERICS FOR TASKPAPER CONTEXT -------
// tpLinesForNode :: TPNode -> [String]
const tpLinesForNode = node =>
foldTreeTP(
x => xs => [
x.bodyString,
...xs.flat().map(
s => `\t${s}`
)(node);
// foldTreeTP :: (TPNode -> [a] -> a) -> TPNode -> a
const foldTreeTP = f => {
// The catamorphism on TP3 trees. A summary
const go = node => f(node)(
node.children.map(go)
return go;
const ws = Application("TaskPaper").windows;
return ws.at(0).document.evaluate({
