Is there a way to check if current line selected has a tag attached in code?
I want to create a KM macro that will first check if the current line I have selected has any kind of tag attached to it, if yes, it will remove it, if not, it will add a tag @ask for me.
So given this:
57
Pressing the macro would do:
57
And given:
58
Macro would add the tag instantly:
58
I can’t quite figure out how to do the check whether the tag exists (ideally there is some applescript/jxa I can run that would return true or false).
And I also can’t find code to quickly add a tag. There is hotkey for removing tags thankfully.
I only have this macro for adding a tag to end but that is not ideal.
59
Thank you for any help.
Here’s a script that will do that I think:
	let outline = editor.outline
	let currentItem = selection.startItem
	if (!currentItem) {
		return
		var removedTags = false;
		for (let each of currentItem.attributeNames) {
			if (each.startsWith("data-") && each != "data-type") {
				currentItem.removeAttribute(each);
				removedTags = true;
		if (!removedTags) {
			currentItem.setAttribute("data-ask", "");
	editor.moveSelectionToItems(selection)
Thank you :orange_heart:
