Invisibility of self-links
Self-links disappear completely when “View | Hide Syntax” is on:
[http://google.com](http://google.com) will not appear at all.
The use of <> (<http://google.com>) works fine (= visibility), but I’ve noticed that when I open such code (from nvALT) with FoldingText, it is automatically transformed into the other (invisible) form.
Could it be possible to either transform to the <> form or indicate “Link” or something?
There is exactly the same problem of invisibility with images without alt text:
![](http://www.foldingtext.com/static/logo.svg): could it be possible to indicate just “Image” or something like that in this case?
Thanks
Links like this [http://google.com] work in FT and NvAlt
(and in MD generally, I think)
[http://google.com] – (the bracketed sequel is redundant when the name itself is a link)
Ah …
Not in Marked.app, I see
More complicated than I thought: this behavior is not permanent, now it works fine, I do not know why.
My usual workflow is to create texts in nvALT, and if they are too long, to edit them in FT. That’s how I’d noticed I couldn’t see the <http://example.com> in FT.
Unselecting “Hide Syntax” showed me all the URLs in <http://example.com> format had been transformed into the [http://example.com](http://example.com) format.
I guess it’s because “Hide Syntax” hide all URL, and in this case also the one inside square brackets, which is fine, but may be there is a possibility to systematically use the <> format (and transform into it if necessary).
And indeed, the tests I’m doing right now do show the good behavior: the <> format is now kept perfectly and I can’t reproduce what I couldn’t avoid a few hours ago.
BTW: in my tests right now, FT and nvALT have the same behavior on these:
  • Edit | Copy | Copy as HTML of: <http://example.com> (followed by a Space Return) gives: <p><a href="http://example.com">http://example.com</a> </p>
  • Edit | Copy | Copy as HTML of: [http://example.com] (followed by a Space Return) gives: <p>[http://example.com] </p>
The only surprise is that the <p> and </p> (including these 2) appear in green in FT, except for the first ones who do not change of color…
I ran into this same issue today, and am glad that it is already being discussed here. Just wanted to add that use of the square-brackets-only syntax (e.g. [http://google.com]) doesn’t seem to be supported everywhere and I can’t see that in the original Markdown specs.
I noticed this applies to links of the form [www.example.com](http://www.example.com/path/to/deep/link) I haven’t experienced any intermittent behaviour described above, these links are just invisible with hide syntax option switched on.
I can’t tell whether this is the behaviour that was intended, but I do find it inconvenient, I was looking for some CSS to fix it, but I haven’t investigated the behaviour of the links, so I might be wasting my time.
