How/where to change code block syntax css?
Really liking FoldingText since discovering it a couple of weeks ago.
I have customised FT with a dark theme (Solarized) which is great except the syntax highlighting doesn’t change at all - normally it wouldn’t be a huge deal but I am currently reading lots of course notes which mix code blocks with text, and reading the code itself gets pretty difficult.
I can see references to ‘cm-mode’ when I inspect the elements but I’m unsure as to where these tags are being styled?
Not sure if you have found your way from the FoldingText menu system to
Help > Software Development Kit > Documentation > Create Themes ?
or:
x-foldingtext://sdk/docs
and
file:///Applications/FoldingText.app/Contents/Resources/dist/sdk/docs/tutorial-Themes.html
(The SDK version of the editor updates immediately when you save an amended .less file, very useful for rapid experimentation. The main editor only reads the .less on launch)
Thanks a lot for the info!
Yes I had followed those links but never realised about the editor updating in Debug mode… that’s great.
I think what was happening was I was editing the SDK version of base.less which of course wasn’t having any effect. Once I copied the ‘cm-mode’ properties into user.less everything worked as expected. Thanks for your help!
