No changes desired on this. I am thrilled with this part as is.
Rob—this is great. It is helping me gain insight into how JavaScript parses code.
The (0) part points to the first tab, right? And what I want is the frontmost, or current, tab.
This made me think, then analyze, then research. “.” is sort of like “of” in AppleScript, right?
I took [tabs.at(0).name()] and adjusted it to:
[windows[0].currentTab.name()]
…and that seems to work well.
I am not sure why windows[0] needs to be there, but the code fails without it.
One oddity: If I run the script with Safari as the active app, the script works as expected. However, if Safari is hidden, and has multiple windows open, the tab that is grabbed is from a different window. Does the window index renumber if Safari is hidden?
Perfect! You rock!
So, do you have an Amazon wishlist? If you don’t want to post it publicly, please DM me.
The current iteration, which is now in active use in my workflow, is:
"use strict";
fpMobile = "~/Library/Mobile Documents/",
fpWorkflows = "iCloud~is~workflow~my~workflows/",
fpLinks = "Documents/Links.txt",
fp = `${fpMobile}${fpWorkflows}${fpLinks}`,
strFullPath = ObjC.unwrap(
$(fp).stringByExpandingTildeInPath
tp = Application("TaskPaper"),
doc = tp.open(Path(strFullPath));
// main :: IO ()
const main = () => {
const windows = Application("Safari").windows;
return either(
// Left channel message in case of a problem.
msg => alert(
"Copy Safari tab list to TaskPaper"
)(msg)
// Simple string value returned if all is well.
x => x
bindLR(
0 < windows.length ? (
Right(windows.at(0).tabs)
) : Left("No windows open in Safari")
)(tabs => {
dateString = taskPaperDateString(
new Date()
).slice(0, 10),
linkStrings = zipWith(
name => link =>
`- ${name} → ${link} @link(${dateString})`
[windows[0].currentTab.url()]
const result = doc.evaluate({
withOptions: {
projectName: "Links",
linkTexts: linkStrings
return Right(
(doc.save(), result)
// -------------------- TASKPAPER --------------------
// TaskPaperContext :: Editor -> Dict -> String
const tp3Main = () => {
outline = editor.outline,
xs = options.linkTexts,
target = outline.root;
const children = xs.map(
txt => outline.createItem(txt)
target.insertChildrenBefore(
children, target.firstChild
return xs.join("\n");
// projectFoundOrCreated :: TP3Outline ->
// String -> Bool -> TP3Item
const projectFoundOrCreated = outline =>
// A reference to a TaskPaper Project item,
// either found in the outline, or created
// at the top of it.
projectName => {
k = projectName.trim(),
matches = outline.evaluateItemPath(
`//project "${k}"`
blnFound = 0 < matches.length,
project = blnFound ? (
matches[0]
) : outline.createItem(`${k}:`);
blnFound || outline.insertItemsBefore(
project,
outline.root.firstChild
project
return tp3Main();
const alert = title =>
s => {
const sa = Object.assign(
sa.activate(),
sa.displayDialog(s, {
withTitle: title,
buttons: ["OK"],
defaultButton: "OK"
s
// Left :: a -> Either a b
const Left = x => ({
type: "Either",
Left: x
// Right :: b -> Either a b
const Right = x => ({
type: "Either",
Right: x
const bindLR = m =>
mf => m.Left ? (
m
) : mf(m.Right);
const either = fl =>
fr => e => e.Left ? (
fl(e.Left)
) : fr(e.Right);
// iso8601Local :: Date -> String
const iso8601Local = dte =>
new Date(dte - (6E4 * dte.getTimezoneOffset()))
.toISOString();
// taskPaperDateString :: Date -> String
const taskPaperDateString = dte => {
const [d, t] = iso8601Local(dte).split("T");
return [d, t.slice(0, 5)].join(" ");
const zipWith = f =>
// A list constructed by zipping with a
// custom function, rather than with the
// default tuple constructor.
xs => ys => xs.map(
(x, i) => f(x)(ys[i])
).slice(
0, Math.min(xs.length, ys.length)
