Hard Return in HTML
In documentation a “shift-enter” or “enter” is said to be converted in HTML to a “hard return”. I’m finding that I have hit key or combination twice to get the hard return. Note: I typically write something in Folding Text then copy as HTML and then paste into Google’s Blogger.
I think you might be right there. I’ll have to take a closer look and update the documentation for that. Thanks for pointing it out.
Regards,
Mutahhir
Thanks.:slight_smile:
