From MAS to non-MAS
Hi Jesse,
is it possible to change from the MAS (Mac App Store) to a non-MAS version? It was/is possible via dev-versions.
I would like to use the non-MAS version in order to ‘sync’ the theme via a symlink. In the MAS-version it is not allowed to link outside the sandbox container :frowning:
regards,
feek
I think it should be the case that if you run the latest MAS version once then you can run the latest non MAS version without having to license it separately.
