FoldingText Save As MS Word .docx
Saving a FoldingText 2 Outline as a .docx MS Word file
This script is an Applescript wrapper for FoldingText 2 which calls:
Installation
  1. Install Pandoc from http://johnmacfarlane.net/pandoc/installing.html
  2. In Terminal.app, check the path of the pandoc command by entering the command:
    type -a pandoc
  3. In the Applescript, check the property pstrPandoc (near the top of the script), and edit its value, if necessary, to match the path returned by type -a pandoc e.g:
    property pstrPandoc : "/usr/local/bin/pandoc"
  4. Install MultiMarkdown from http://fletcherpenney.net/multimarkdown/install/#macosx
  5. In Terminal.app, check the path of the pandoc command by entering the command:
    type -a multimarkdown
  6. In the Applescript check that the property pstrMMD (near the top of the script), and edit its value, if necessary, to match the path returned by type -a multimarkdown e.g:
    property pstrMMD : "/usr/local/bin/multimarkdown"
You can then run the script from something like KeyBoard Maestro or FastScripts
  • Hash headers level 1 to N in your FoldingText document will become MS Word outline Heading Levels 1 to N
  • Indented list items will be correspondingly indented
  • The document can be further styled by changing the MS Word theme.
Alternatively, to export from FoldingText to MS Word in a way that directly applies CSS stylesheet formatting, and also offers formatted PDF exports, try Brett Terpstra’s excellent marked2.app
FoldingText Extensions Wiki
Export to a common document type
