FoldingText for Atom – 0.7.0
  • Adds context menu items for opening, copying, editing, and removing links.
  • Fixes some cases where pasting text would create a link.
  • Fixes (maybe) installing on windows… please let me know! :slight_smile:
  • Fixes bad links created when dragging a file from desktop into an outline.
Here are the Installation instructions for FoldingText for Atom.
Windows install worked just fine for 7.0, even considering I’ve made a hash of my .atom directory trying to figure out a way of manually adding an older version of Folding Text.
It’s a bit tricky to do a complete uninstall of Atom on Window.
Thanks for testing and good to hear that it works now. If you have a chance please test out linking between outlines. That requires a bit of file path code that I haven’t tested well for windows.
Will do. I’ll try that tonight and let you know.
I couldn’t get the linking within files or between files working on Windows with Atom 1.0 and FT3 0.7.0. Drag and drop works fine but I couldn’t create a link using any key modifier (ctrl, alt, shift, Windows) when dropping.
It all works fine in OS X.
When in Windows I can follow a link created in OS X and it opens the right file but the file is blank … though I can open the file properly from the menu and it displays fine. The path finds the right file but seems to append a * to the end of the file name in Windows.
I didn’t have much time to experiment with it yet. I’ll dig in a bit more over the weekend and get some more useful information.
