FoldingText Extensions Wiki
Use this wiki to link to posts about FoldingText workflows, themes, scripts, and plugins. If you post an extension please add a link to that post here to make it easy for others to find your post in the future.
Workflows
Themes
Scripts
Plugins
Command Line Tools
How to install a plugin?
Move archive to new file
pinned #2
unpinned #3
Hi Jesse - Not sure what may have happened, but a number of the links of the extension Wiki are not working or take me to a blank screen.
Can you take a look?
Thank you
Karl
Thanks… I didn’t test them all, but I just fixed a bunch that were linking to support.foldingtext.com instead of support.hogbaysoftware.com. I guess those started breaking when I started autoforwarding from the foldingtext.com url.
