Find and Replace power options
Two questions about finding and replacing.
  1. I can’t seem to see a way to add a tag to the end of every task. I hoped I could use the power feature similar to WORD, where I could replace )^p [for paragraph mark) with ) tags(cool_new_tag_I’ve_created)^p but that doesn’t seem to be an option. TP can’t find the initial to do a replacement.
  2. I don’t want to risk a second mistake. If I make a selection and choose Replace All, is the replacement limited to the selection, or does it replace everything in the document? My impression from trying it once was that everything was replaced in the document, so I undid and tried for manual replacement. Didn’t have time to muck around.
Thanks for any help/response.
