Endless loop when starting (standard yosemite)
Everything is in the title.
Menus are available, help as well.
But most menus items are not and I get a white square and a wheel.
I have to kill the process.
Can you try running FoldingText from your Guest user account and see if that works?
I expect that will. If so it means there’s likely to be something messed up in FoldingText’s settings (in your account). You can try to clear and reinstall FoldingText using a tool like AppCleaner.
Did that. Now works perfectly.
Thanks a lot, that was fast.
By the way, please develop an outline view of the document on the left like in TaskPaper.
Thanks a lot
