Easier reordering for lists
I was wondering if it would be possible to have an easier way to drag rows in lists around. I particularly like the feature in the Editorial and Drafts iOS apps where you can access an ‘Arrange’ mode where each row of text has a drag handle on the right hand side to move it up and down. Would something like this be possible?
Many thanks
Adrian
In the meanwhile the FoldingText > Organize keystrokes do work well, I find:
Thank you. I hadn’t noticed that menu option, very handy.
I still think handles at the right would be perfect for easy reordering with a mouse but the keyboard shortcuts are working well.
Adrian
