Disable auto capitalization in code blocks
I would love for Bike to auto capitalize text in code blocks. It behaves fine when I use Command-Shift-` for an inline code block, but when I use the ``` shortcut and then type something like “var”, it auto capitalizes to “Var”.
I think you mean NOT here?
Assuming that’s the case, then I think this issue if fixed in the current Bike 1.14 Preview (152). Plan is to release that on Mac App Store tomorrow… assuming I can make demo video before then. Keep running into delays, but think, I’ll manage it later tonight.
Oops! Yes, I did mean NOT. Thank you!
