Details of x-foldingtext:// and x-taskpaper:// url schemes
Does the documentation describe the x-foldingtext:// and x-taskpaper:// url schemes ?
I know we have:
x-foldingtext://sdk/docs
and
x-foldingtext://sdk/runtime/editor
but I seem to have forgotten the syntax for clicking to applying a nodepath query to the open document.
EDIT: Ah … I had forgotten ⌘’ Run Command > link node path
(In particular I wondered whether the scheme includes, at the moment, a way of jumping to a particular line number or character offset from the start of the document - something like ?location= or ?linenum= )
I started typing out a question/suggestion regarding a URL scheme for TaskPaper but Discourse scooped me by suggesting this existing thread.
May I ask, does x-taskpaper links really exist :sunglasses: and if yes, how?
It would be fantastic to be able to link to particular entries in a TaskPaper file.
I’ll aim to tidy an informal tp3doc:// script for TaskPaper 3 this weekend
Fantastic, looking forward, and thanks!
I am a newbie here. thanks to Rob T for all his great scripts.
Not sure about this error. can get folding text selection url to work but the tp3doc:/// does not work.
the url handler registration is ok and able to open the file correctly but creating a link to a section of the text does not work :((
can you please help
thanks
Error
"ReferenceError: Can’t find variable: require
evaluateScript
property pTitle : "Copy TP3 selection as tp3doc:// url"
property pVer : "0.02"
property pAuthor : "Rob Trew"
property pDescription : "
Copies the selected text in TaskPaper as an tp3doc:// URL
linking back to the current document, filter state,
and (if still identifiable by nodepath, search string or line number), selection.
(Uses the tp3doc:// url-scheme - registered and handled by the OpenTP3DocAtLine.app applescript app bundle)
property pstrJS : "
function(editor, options) {
var libNodePath = require(‘ft/core/nodepath’).NodePath,
tree=editor.tree(),
rngSeln = editor.selectedRange(),
oFirstNode = rngSeln.startNode,
dctStartOffset = rngSeln.startLineCh(),
dctEndOffset = rngSeln.endLineCh(),
strNodePath = editor.nodePath().toString(),
strSelnPath = libNodePath.calculateMinNodePath(oFirstNode),
strDocPath=options.docpath,
strURL=’’, strText,
strEncoded,
lngLine = dctStartOffset.line,
lngStartOffset=dctStartOffset.ch,
lngEndOffset=-1,
lnPosn;
if (dctEndOffset.line === lngLine) {
	lngEndOffset = dctEndOffset.ch;
strURL='tp3doc://' + strDocPath;
if (strNodePath !== '///*') {
	strURL += ('?nodepath=' + strNodePath);
if (strSelnPath.indexOf('@id') < 0) {
	strURL += ('?selnpath=' + strSelnPath);
strText = oFirstNode.text();
if (strText.length > 2) {
	strURL += ('?find=' + strText);
if (lngLine) {
	strURL += ('?line=' + lngLine.toString());
if (lngStartOffset) {
	if (lngEndOffset) {
		if (lngStartOffset !== lngEndOffset) {
			strURL += ('?startoffset=' + lngStartOffset.toString());
			strURL += ('?endoffset=' + lngEndOffset.toString());
return encodeURI(strURL);
on run
set varResult to missing value
tell application "TaskPaper"
set lstDocs to documents
if lstDocs ≠ {} then
set oDoc to item 1 of lstDocs
tell oDoc
set strPath to POSIX path of ((file of it) as alias)
set strURL to (evaluate script pstrJS with options {docpath:strPath})
set the clipboard to strURL
display notification "tp3doc:// link copied …"
end tell
end if
end tell
return strURL
end run
That version is for a much earlier iteration of TaskPaper development. I’m planning to write a new version for the current TaskPaper 3.
Thanks for the reminder.
ok great thanks. appreciate these great tools.
Any update to this? thanks
Won’t be this week, but I’m hoping to look at it at the weekend.
Great thanks.
trying my luck here :slight_smile:
Thanks – life, or rather its converse, has intervened a couple of times in these weeks. I’ll try again this weekend.
completely understand. thanks!
Any update to have this. it would be great to have a menu for item, copy as hyperlink.
thanks
Yes — very much +1 here.
Specifically I’m looking to “Copy as Link” on a node and be able to post that into a different document.
Any luck in getting this done?
using more and more of TP3 (about to abandon Omnifocus). can we get this working please? thanks
nara
Any chance of getting this working ever?
