Cut/Copy Paste not working
I just did a clean install of Sierra, and installed Folding Text from the App Store. When I cut or copy text, and then try to paste it, nothing happens. The menu “blinks” letting me know it got the keyboard shortcut. And when I use the dropdown menu it doesn’t work either. I tested cut/copy paste in other applications and it is working fine. Please advise.
Hmm, that’s odd. Does the paste work with:
  • Text copied from other apps?
  • Using the Menu?
Regards,
Mutahhir
