Cursor Not Following Page Movement
Slightly uncertain whether this is a bug, a feature request, or just behaviour that’s expected but not helpful to me personally.
Paging up and down through the document (PgUp and PgDn / Filco KB) the text pages into view as I’d expect, but the cursor stays where it is.
This means that if I move the cursor, I’m transported back up or down the document.
I find this very jarring and incompatible with my expectations coming from Sublime Text.
Is that working as expected? If it’s behaviour that other users generally find intuitive, is there a way I can amend it myself with any kind of workaround?
Cursor behavior makes page jump so insertion point stays in center of page
This is intended, it’s the way that it works in the native OS X text component. But you can also get the behavior your are looking for. Internally there are a number of “page” commands. I’ve listed them here with default keybinding first, followed by internal command name.
Just scroll:
PageUp : scrollPageUp
PageDown : scrollPageDown
Change selection:
Alt-PageUp : pageUp
Alt-PageDown : pageDown
Extend selection:
Shift-PageUp : pageUpAndModifySelection
Shift-PageDown : pageDownAndModifySelection
Those are the defaults, you can change them with a plugin that adds your own keybindings.
Thanks for that - good excyse to dip my toe in the water with plugins
I’ve tried to follow this procedure, using the instructions you’ve posted previously for developing a plugin.
With the plugin in place in the Plug-Ins directory, and after a restart, the two taskpaper files look totally empty when I open them - no text on display. no hidden white-on-white text to select etc.
When I move the plugin sub-folder out of the Plug-Ins directory and restart, the taskpaper files open and work without issue.
This is the entireity of the package and main files:
    "name": "Hello world",
    "version": "1.0.0",
    "description": "Seans Custom Keys!'",
    "engines": {
        "foldingtext": ">=2.0.0",
        "taskpaper": ">=3.0.0"
    "homepage": "https://mrsean2k.wordpress.com"
    var Extensions = require('ft/core/extensions').Extensions;
    Extensions.addInit(function (editor) {
        editor.addKeyMap({
            'PageUp': pageUpAndModifySelection,
            'PageDown': pageDownAndModifySelection
The problem is in:
It should be:
'PageUp': 'pageUpAndModifySelection',
'PageDown': 'pageDownAndModifySelection'
I didn’t spot this just by looking at the file. Instead I put your plugin in my plugins folder and then opened Help > Software Development Kit > Editor and clicked on the “Inspector” toolbar item. And there the error was pretty easy to see.
Ok, thanks - I think I saw an example that appeared to be a function reference and not a string, and one of the example plugins used an anonymous function inline so I made an incorrect assumption
I think the real problem is that I’ve wandered in as a previously non-FT user without even a cursory look at the documentation. Best do that before any more questions.
Ta!
