Cmd-D no longer applying @done. Help!
Cmd-D is no longer applying @done, which is a real problem for me (I use the .todo mode heavily). Is this a bug or is there something I’m missing? It’s been this way since I installed the upgrade.
Best,
Ryan
Hi Ryan,
You should be able to get the done commands to work again by removing and downloading the ‘toggle tags’ plugin again.
Do let me know if that doesn’t help.
Regards,
Mutahhir
Hi Mutahhir:
Yup, that did the trick!! I didn’t replace all of the old files in the plugin folder.
Thanks very much! Loving this app, great update.
Best,
Ryan
Awesome! :slight_smile: Thanks!
Regards,
Mutahhir
