Change Link Color
Is there a way to change link color? I tried linkColor, which didn’t work. I have basically zero knowledge regarding css, so sorry for the stupid question. : )
Thanks.
My user.less looks like this for the work I’m doing today – it’s making the links red on hover and otherwise gray.
@base: #727DA8;
@fontFamily: Consolas;
@paperColor: #fcfcfa;
@textColor: darken(@base, 20%);
@cursorColor: red;
@cursorWidth: 2px;
@indicatedColor: red;
@foldColor: mix(@base, white, 50%);
@foldedLineColor: mix(@base, white, 50%);
.CodeMirror {
	.cm-syntax {
		color: mix(@base, white, 50%);
	.cm-keyword.cm-lead {
	.cm-list-bullet {
Hi complexpoint, thank you for the reply!
In your code, does the textColor line define link color (when not on hover)? I’m trying to give link a different color from general text, say, URLs in blue but other text in black.
In mine that’s just a red hover.
Have you tried:
@interfaceColor: blue;
More generally, Jamie Kowalski’s quite fully developed theme is a good source of examples:
Worked like a charm! Thank you so much!
