one can modify the font of the task lists, but not of the sidebar. Am I right?
And if you are not planning to make it possible to change the font of the sidebar (as I expect), could you please change the font-family of the sidebar to the new Apple System Font? Like other build-in apps.
Correct. In the future I may make it an option, but it’s not possible now.
I though this was already the case… though my eyes aren’t great at picking out differences between fonts . In interface builder the font for the sidebar set as “System Regular”. I don’t think that I ever changed that value, so I think that’s what most apps should have by default. Can you take a screenshot or two to point out the differences to me?
I’m pretty certain that we are not supposed to select specific fonts like that in Interface Builder. I think they want use to choose a generic “system font” in case it’s changed again in the future. When I print out the actual font that’s being used at runtime it reports as:
“.AppleSystemUIFont 13.00 pt. P [] (0x600000042c70) fobj=0x100606a20, spc=3.59”
And I “think” AppleSystemUIFont is really San Fransisco?
What other apps are displaying the using the font that you want in a sidebar UI? I just tried Apple’s Notes and Reminder apps and they both seem to display as TaskPaper is.
