That worked well, thanks! My introduction into Scripts!
A small thing of note, that is NOT a concern for me, but to let you know. I sometimes include tags inline, like:
- Talk to @Scott about the project deadlines
When your script acts on a tag, i.e. finds Mixed or CAPS, it moves the tag to the end, so that one becomes
- Talk to about the project deadlines @scott
It would be nice to put the Scripts in a menu in TaskPaper. I don’t use Command Palette that much, maybe I should. @jessegrosjean what is “Lower Case” in the command palette do? I named my script something similar and saw it
Task Paper help points me to the Script Editor help which says I can put a script into the menu by putting it into a certain script folder, but Task Paper needs it in its own folder. So does not seem like I can add my script to a system script menu in Task Paper, am i reading it wrong?
