.Calc recognises a bullet point as a minus operator
Using bulletpoints in .math to organize calculations, will lead to miscalculations. Because bullet points are made from the text '- '. For example, the answer of the code below should have been 25, but shows as -25.
.todo
- 5 * 5
To prevent confusion, I think bullet points should either be turned off under .calc or be ignored by the .calc module.
Hi Jasper,
Thank you for writing in about this. I’ll look into fixing this for the next release. I’ve added an issue about it here. Please feel free to add a comment there if you have any more information about this.
Have a nice day!
Regards,
Mutahhir
Hi Jasper,
Just wanted to let you know that we just launched a 2.1.1 dev version which resolves this issue.
Enjoy!
Regards,
Mutahhir
