Bullet numbers don't update automatically
There is a bug in FT with the numbered lists. For example, if I’m using this list:
1. One
2. Three
3. Four
And I want to add an item after number 1, it doesn’t update the numbered items automatically. I get this:
1. One
2. Two
2. Three
3. Four
I edited your post so that the problem would show up… your lists were being processed by markdown which automatically fixes that issue.
Anyway this is an issue that I know about. Still trying to decide if I want to add code that will automatically fix this. But in the meantime you can use Format > Lists > Ordered List (Shift-Command-L) to correct this as described here:
Hi, I came here to find a solution to the same problem.
Your manual “Format -> Lists -> Ordered List” solution works fine!
Please do NOT “fix” this. It shouldn’t be automatic. I like a lot how we can just manually fix the numbers when we want to. Gives us more control. Can you keep it like this?
