Birch 1.4.0 Dev Release
Release Notes
  • Added search bar (similar syntax to FoldingText)
  • Fixed focus is set correctly when opening an outline.
  • Fixed loading process to only display outline when fully loaded.
  • Fixed some flashing that happened when clicking to set selection.
Install Birch
The search bar syntax is same as FoldingText with these exceptions:
  • The current hoisted node is considered “root”
  • Removed filter-decedents (///) axis. Now that we can really hoist items it’s not needed I think.
  • The default axis for the first segment of a non-absolute path is descendent. Confusing… but it means if you just type a search with no special syntax then the entire hoisted outline will be searched. If you start your path with leading / then child will be default axis searched.
