Birch 1.3.0 Dev Release
Release Notes
  • Added indication when outline is hoisted.
  • Changed to Option-Command-Up/Down to hoist/un-hoist.
  • Changed to Command-Click on item handle to hoist the item.
  • Dropping file on editor inserts a link to the file.
  • Drag and drop no longer allows dragging item as child of itself.
  • Changed root id in .bml file from Birch.Root to Birch
  • Changed Shift-Click on item handle to fully expand/collapse.
  • Fixed problem where editor could lose focus when hoisting.
Install Birch
