Bike to WriteRoom
The new WriteRoom is a thing of beauty.
I’ve been using Hog Bag Software since the days of Hog Bay Notebook, but I’ve never posted a feature request before, so apologies if I’m repeating something that’s already been asked and answered.
Might there ever be a world where it’s possible to export from Bike into WriteRoom, preserving the hierarchical structure as Markdown?
The Bike 2 Preview menu system has:
Edit > Copy > Copy Markdown Text
( and in WriteRoom, of course, you have the Edit > Fold sub-menu )
Oh, amazing! Thank you!
(And I had indeed missed that sub-menu in WriteRoom; I’d been blithely flicking in and out of Heading Overview Mode.)
@jessegrosjean , do you plan to add some extensive export functionality in its own “Export”-menu in Bike? This would make a lot of processing easier I assume. Workflowy had a feature where it would display exactly how that export would look, you could remove the “-” etc, so it made it easy to create prose from the outline and save to a new file.
I’ll add that you don’t need to do any export if you use Bike’s Markdown file format directly. So when you first save, or Save As choose “Markdown Text”
Then your outline is saved in a nested list subset of Markdown and you can edit it directly in either app.
I haven’t really thought about it, so no plans yet! :slight_smile:
I’m still trying to get WriteRoom 4 out the door, then back to focusing on getting Bike 2.0 out. I don’t think I will add any new export in that timeframe, but after that I’d be willing to think on it.
Oh, I am a buffoon for not noticing this. (In my slight defence, it’s only since the new WriteRoom that I began thinking about using Bike as stage one of what those more organised than I might think of as an “integrated workflow”) Thanks, Jesse!
