I could be wrong, but I think there’s a regression in Bike 1.4 Preview (65) with regard to ‘Enable Typing Animations’. I always disable this preference, but I’m seeing the cursor ‘float/drift’ again when I type despite the preference being toggled off. The ‘Enable Animations’ preference is still set to on as I find the animations when moving rows to be very helpful.
Is this when you type letters, or just when you move cursor with arrow keys?
I think animation is expected when you move cursor with arrow keys, but not expected when you type. I’m trying version 65 now and it appears to be working correctly, I’m not seeing animation when typing.
Anyone else notice a problem?
I definitely notice it when I use the arrow keys. With typing, I don’t think so, but the distances are really very small to accurately tell. If this is by design, then please ignore this post.
Working as intended I think.
