Backing up / syncing
Is there any way to backup or sync across dropbox or other means? I can’t believe I haven’t seen this mentioned anywhere…
Generally you can just save into your Dropbox folder? FoldingText is a document based app, so you can save your files wherever you want.
That’s what I thought was the suggest solution. I will do that. Thanks.
