Archiving Cancelled Items
Being new to scripting and plug-ins, I am having problems setting up something to archive my cancelled items, I want them to go into a specific Cancelled header section (like Archive done). I looked at Jesse’s archive done code and tried to copy it into a new main.js for a plug-in but it does not work. Do I need to do something else in addition to main.js?
Many thanks.
// MB Testing cancelled items
	'use strict';
	var Extensions = require('ft/core/extensions').Extensions;
Extensions.addCommand({
		name: 'archive @cancelled',
		description: 'Move @cancelled items to its own header section.',
		performCommand: function (editor, options) {
			var tree = editor.tree();
			tree.beginUpdates();
			tree.ensureClassified();
			var archiveNode = tree.evaluateNodePath("//@line:text = cancelled")[0];
			if (!archiveNode) {
				archiveNode = createArchiveNode(tree);
				tree.appendNode(archiveNode);
			Node.commonAncestorsForNodes(tree.evaluateNodePath("//@cancelled except //@line:text = Archive//@cancelled")).forEachNodeInSet(function(node) {
				archiveNode.insertChildBefore(node, archiveNode.firstChild);
			tree.endUpdates();
The first goal is for your .ftplugin to show up (without error messages) in FoldingText > Plug-In Manager ( ⌘, )
To go to that stage, you need to add a package.json file to the .ftplugin folder which you have created.
(see file:///Applications/FoldingText.app/Contents/Resources/dist/sdk/docs/tutorial-Plugins.html)
( FoldingText > Help > Software Development Kit > Documentation )
Yes, I did do that already but I don’t have a Github presence as homepage, just a generic site which is not being used, is that important? No errors when looking at plugin but it doesn’t do what I want (the tagged cancelled items just stay where they are) which is why I assumed there was something else missing.
I think the key may be that the section of Jesse’s todomode.js which you are copying uses some functions whose definitions you haven’t included:
function createArchiveNode() is defined before your excision,
and similarly using Node.commonAncestorsForNodes() depends on the
Node = require('ft/core/node').Node, in Jesse’s variable declarations.
(both towards the top of the page)
Your script is unable to evaluate calls to those functions because it doesn’t yet have access to their definitions.
For a more simply customisable approach, you could look at the script below, and perhaps uncomment the line:
-- property precOptions : {archivetags:{"cancelled"}}
If you want to bypass the menu and make it work only with @cancelled tags.
FoldingText Extensions Wiki
This is great, thanks, it works a treat!
I can’t get the plugin to work yet, guess I need to understand how to run a debug, I’ll have a go :smile:
Fixed it, typo as it was case sensitive and I had tagged with @Cancelled and not @cancelled :wink:
(I still can’t work out how to run a debug calling the plugin with text but am working on it).
Debugging with text:
  • Fire up the SDK version of the editor and paste some text into it,
  • place a debugger; statement somewhere in the code,
  • launch the code (either with a plugin keystroke, or, in the case of an applescript, by replacing the word evaluate with debug).
