Add key binding
Hi!
I am trying to bind ‘Alt-C’ : ‘formatCodeblock’ and it’s does not work.
Please help, main.js:
    'use strict';
    var Extensions = require('ft/core/extensions').Extensions;
    Extensions.addInit(function (editor) {
        editor.addKeyMap({
            'Alt-C' : 'formatCodeblock'
    }, Extensions.PriorityLast);
Hi… I think the braces don’t match up in that example. In particular I think you’ve got an extra brace after the Alt-C line. I’ve removed that and this is working for me:
  'use strict';
    editor.addKeyMap({
