I would like to use this app for paragraphing writing. To that end, I would like this app to be able to combine multiple lists into one list.
Like this
- abc.
- def.
- hij.
β
- abc. def. hij.
Like this
β
Iβm not sure if this makes sense for a built in command, is this a standard thing that other apps do? If so can you point me to those apps?
The good news is I think this is a perfect situation for a script solution. Can you explain a little more on how exactly the command should work? Does it work on the entire outline? The current selection? Children of the current selection?
This feature once existed in an outliner called MORE for Mac, but no outliner currently implements this feature.
It is intended to be merged by selecting children of any level from each other (i.e. Children of the current selection).
Ideally, this would work by simply pressing a single command, but it can also be accomplished by scripting.
Please try this script on the following outline:
Parent
one
two
three
Place text caret in βParentβ row. Then run script. End result should look like this:
Parent
one β’ two β’ three
tell selection row
set entireContents to entire contents
-- Do nothing if no contained rows
if entireContents is equal to {} then
return
end if
-- Collect names of all contained rows
set names to {}
repeat with each in entireContents
copy name of each to end of names
end repeat
-- Concatinate row names into single string
set saveTID to AppleScript's text item delimiters
set AppleScript's text item delimiters to " β’ "
set concatinatedNames to names as text
set AppleScript's text item delimiters to saveTID
-- Delete existing rows and replace with single concatinated row
delete rows
make row with properties {name:concatinatedNames}
end tell
end tell
I used the script you gave me and it worked (saved as an application). Thank you!
