A visual bug when quickly expanding/collapsing nodes
hi. Bike 1.9 (112), macOS 13.1. when quickly hitting cmd-0/cmd-9 there’s a visual bug
here’s a short video as well: Screen Recording 2023-03-15 at 11.30.06
Do you have animations disabled in settings?
yes, disabled
Thanks, I’m now seeing a number of similar bugs when animation is turned off. Will try to fix in next release. In the meantime if you enable animation I think problems don’t happen. There’s a slider for animation speed, so you can set to a pretty fast speed if you feel animations slow you down.
