TaskPaper crashes on startup
When I shut down, checking the box “open windows when logging in again”, it looks as though TaskPaper crashes every single time when opening again automatically. I can’t even press the “reopen” in the dialog box because it crashes even if I do. Is this a known bug? Does this happen to anyone else?
I’m on Taskpaper version 3.6.2 on macOS Sierra 10.12.3.t
This isn’t a known bug. I guess it must be that there’s a bug showing up when TaskPaper tries to re-open a particular file. Can you try the latest preview release… it think it fixes a problem when opening files that have odd newline sequences (might show up if you’ve edited your files in editors other then TaskPaper)
